Hi, I have been through all of the search results about dual gimbal support. The topics just fell off with no apparent resolution. Can anyone advise on how they have successfully used Pix4DCapture with any of the m210 gimbal setups. I want to fly a mission that collects data with an RGB camera and MS with a Micasense Rededge MX. Is this possible with Pix4DCapture or are you using other software. Thank you very much.
Hello Scott, PIX4Dcapture doesn’t support the capture of images using a dual-camera setup. PIX4Dcapture supports Matrice 210 and Matrice 210 RTK, so if you are using this drone, you can download the PIX4Dcapture software and use it with the single gimbal.
