hallo
I want to build cross section after processing, but I cant find the tools on Pix4DMapper. I want to make lay out of that. Can you help me?
thanks
best regards
hallo
thanks
best regards
Hi Christovel,
There is no such tool in Pix4Dmapper as it is made for processing and generating the outputs.
However this feature is available on Pix4D Cloud.
Elevation-profile-and-cross-section-on-the-cloud
You can use Pix4D outputs in a GIS such as QGIS or ArcMap.
https://gis.stackexchange.com/questions/30018/drawing-cross-section-in-qgis
https://desktop.arcgis.com/en/arcmap/latest/extensions/3d-analyst/fundamentals-of-creating-profile-graphs.htm
Hope this will help.
Best
halo
i cant find tools of this link
i use trial account, can u help me ?
thanks
best
Hi Christovel,
If you trial license is still valid you should be able to create project in the Cloud.
As precisely described in the article, if you open one of your processed project, you will be able to see the cross section tool:
Click on it, draw your section and click on generate:
Best
halo,
if i want to print that cross section, is there any tool to save it or print it?
thanks
best regards
hello,
is there any tool to know elevation on 1 coordinate? only just 1 coordinate
thanks
best regards
