Color selection of several points via box, over the whole point cloud.
This would help with canopy / vegetation filtering. If I select multiple points in the foliage, and then have the software search for other points matching those, I would get a more accurate result because I can keep my tolerances low. It would also be great to have the ability to run this over the entire point cloud vs the diameter limitation that’s currently in place.
Hi Chris,
Thank you for your feedback.
Are you trying to filter the vegetation, I suggest you use the Terrain Filter. You can modify the settings in order to adapt it to your needs:
If you mean something different, please show me a couple of examples.
