I’m finish the mission. My dji mavic is landing, but it’s no power, and shut down. so I replace the battery , and then CAN NOT find the photo (include the software and the micro-sd card)…
I NEED FIND IT OUT, because it’s HARD to fly again.
So, where can i find it out…
thank you very much!
For optimal experience with Pix4Dcapture, we recommend to proceed with basic checks:
https://support.pix4d.com/hc/en-us/articles/115004119343
This article helps users to troubleshoot app issues, and you can find the active community thread on the missing images topic here:
https://community.pix4d.com/t/2910/comments/115004714086
Are you that you selected the right model? I had the same issue with a phantom: flight ok, photo position on the map, drone landed but the Sd card was empty. The app at certain point resseted the model (I don’t know if it was a my fault or an app issue).
Under mission manager you should able to see which model is selected.
I suggest to check very carefully all parameters before starting the mission.
