Hi, is it possible to know which software is more suitable to animate paths, demarcating areas etc. And which respective output format from pix4d is best suited for the preferred software.
I have tried to animate video paths from pix4d and then use them to edit via premier pro, but I believe that it would be much easier if a separate software is available that can import the 3d mesh and edit. Thanks in advance
