Looking to map 2400 acres and the resolution doesn’t need to be as precise (1-3"), but more like 6" to 12". Anyone have a rule of thumb for mapping acreage based on the kind of resolution and the time it would take just to capture all the pictures?
Hi Greg,
If you know the resolution on the ground or the Ground Sampling Distance (GSD) you would like to have (6" to 12"), as well as which camera will be used. It is possible to calculate the height at which the images should be taken, more here: https://support.pix4d.com/hc/en-us/articles/202557469
Then, to achieve a certain overlap between the images at the desired GSD, and taking into account the speed at which the drone is flying, it is possible to calculate the time interval between each image. More here:
flight plan: https://support.pix4d.com/hc/en-us/articles/202557459#label1
time interval: https://support.pix4d.com/hc/en-us/articles/202557479
The duration of the mission can be calculated based on the speed of the drone, the flight plan and the size of the area. For example, if you have a grid flight plan and you know the size of the area, you can know the length of each line in the flight plan, and based on the speed of the drone you have chosen, you can calculate the time it will take to fly the mission. For larger areas, the autonomy of the drone (battery time) should be taken into account, it could be that the battery has to be changed which would add time to the mission.
Depending on the drone you have, Pix4Dcapture, our flight planning app, might be interesting for you. More here: https://community.pix4d.com/t/4464
