Yes, at the moment for the M210 RTK V2 the supported camera is the DJI Zenmuse X5S with the lens model DJI MFT 15mm/1.7 ASPH.
If a different lens model is mounted over the X5S, then you would need to account for the different specifications for planning the mission.
A lens with a bigger focal length (e.g. 45 mm) results in a smaller field of view and a lens with a smaller focal length (e.g. 5 mm) results in a bigger field of view. So, in order to achieve a sufficient overlap between images, you would need to increase the default values in the app (increase the default 75%).
And about the zoomed images; if you plan to take zoom images and standard images, we would not recommend uploading both to the same project as you would no obtain a good 3D model. Remember that in order for PIX4Dinspect to process the images as expected, they need to meet certain criteria (more info in our How to scan cell towers - PIX4Dscan article).
