speed variabilities between flight paths
Hi all,
just having an issue with pix4d capture on iPhone
it flies one line at normal speed eg. 10m/s and the next adjacent leg at almost half the speed.
its really frustrating specially when you have a big flight.
any help is much appreciated.
regards,
taz
The behavior that you are reporting is not expected and the speed of the drone should be more or less constant during the flight.
Are there any external factors, e.g. wind, that could influence the speed of the drone?
For optimal use of Pix4Dcapture, we recommend to proceed with basic checks: https://support.pix4d.com/hc/en-us/articles/115004119343. This article helps users to troubleshoot app issues in most cases.
