Saving a Matic merged file name or Save As
In Matic, when I merge a file, it just saves the file under the project name of the “Master” project. It would be better to be able to have it save under a different name (as it does in Mapper) in case an issue is found.
Either that, or allow a “Save As” under the file commands so that the original project is not overwritten.
Hi Austen, I believe you have a workaround to solve your problem. You can create a new project and then merge project A and B there. By doing that, you are keeping the original projects safe. Hope it helps!
Diana
I second the request for a “Save As” feature
