Hi folks
If I complete processing on steps 1 and 2 to using “low res” mesh settings which produces a mesh and 4k texture, can I then produce just a new 8k texture without reprocessing the previously created mesh.
Hi folks
Unfortunately, if you start the process of Step 2 once again, the result will be overwritten.
However, you can move your low-resolution mesh to another folder and start processing Step 2 one more time with different processing options. Afterwards, you can export your mesh to the folder where the rest of them are stored. Learn more How to export the Triangle Mesh.
Best
