Hi to all…sorry for troubble…
I use 3dsmax to build 3d objects. To render “heavy” objects, 3dmax allows you to divide the work, to make the render, on the PCs present in the local network, by installing very light render clients.
when the workload (pix4d mapper)is so much on the pc that I use to do the calculations, I have to wait hours without touching anything in the hope that everything will go well. Many times in offices there are “unused” PCs and it would be nice to be able to divide the workload in order to speed up work.
Sorry for my fantasy ![]()
Hi Mario,
If you want to spread the processing out to other computers then you will need to purchase additional seats for your license. Otherwise, you could try our Cloud option.
