I am processing multispectral imagery collected using a RedEdge-P sensor in Pix4Dmapper. During radiometric calibration, I noticed a significant difference in the reflectance values depending on the correction option I select.
When I select “Camera and Sun Irradiance” correction, the resulting reflectance values decrease from around 0.5 to 0.05. However, when I select “Camera Only”, the reflectance values appear to be within a reasonable range.
Has anyone experienced a similar issue with RedEdge-P imagery? What could be the reason for reflectance values to decrease significantly when Sun Irradiance correction is applied?
