Hi
I have a project taken over dam area, after processing the aerial imagery Im looking to cut out the centre of the dam so this area is essentially blanked out. Then Id be looking to add external values to this existing project. These were taken with a external robotic totalstation and will be water depth of upto -2m.
If I am able to continue I need to export in a planimetric map.
Data captured with M210 v2 DRTK2, no gcps used as RTK was enabled
