I’m currently running a 9950X3D backed with 32gb DDR5 6000mHz that processes datasets relatively fast. I also have a 5070ti on my rig, but my monitoring software shows its fans don’t even turn on during MS orthomosaic construction.
I’ve tried programming my own orthomosaic generator using C++ this time last year, but I hit a hard wall because CUDA 12.9 wasn’t supported in openCV. I haven’t looked into it since, but I’m sharing this because I understand the following request is a tall order.
Can the Pix4D engineering team work on implementing the “GPU acceleration” on MS (.tiff) file types? My datasets are fairly large, and I’d like to take advantage of the hardware I own to increase my processing speeds.
Thank you!!
