DJI released the SDK
May I ask if your feature request relates to PIX4Dcapture and not PIX4Dmapper?
No my feature request relates to PIX4Dmapper.
We need H20T RJPEG support in Pix4DMapper. As mentioned above, the camera thermal SDK has been released for a while now.
It doesn’t look professional to deliver orthomosaic as RGB without any temperature measurement.
we really need this. I don’t know a good thermal mapper solution right now. In addition it would be ideal to integrate the RGB image into the workflow. The higher resolution RGB image should provide additional information to aid in orthorectification of the low res thermal image.
Common Pix4D, Im just going to leave something on the table…
What do you guys think will happen if you make this work? Make the thermal photos of the H20T camera work with Pix4D mapper so people can get thermal orthomosaics with temperature data?
Dont you think that MAYBE, Terra Users could switch and buy Pix4D Mapper instead, JUST because of this adjustment?
As simple as that. Its up to you.
As mentioned, DJI released their SDK.
You got the free pass there.
This is a necessary feature moving forward (H20T & M30T RJPEG support) as DJI keeps releasing new drones incorporating their proprietary thermal imaging processing.
I have a Pix4DMapper perpetual license and would like to continue using it as my go-to tool for mapping and thermal imaging. But, as a mechanical engineer, I need that temperature data as part of my analysis and deliverables.
Moving from the Matrice 210v2 with multiple payloads to a more compact unit (like the M30T) combined with Pix4DMapper to make my job a lot easier.
Please incorporate this feature as quickly as possible.
Thanks!
Hi, I have DJI H20T and am using Pix4d Mapper. Really hope to see Pix4d Mapper can convert RJPG of thermal image to tiff and generate thermal map with the software. So, may I know any prospective planning in Pix4d to solve the current dilemma?
