Pix4Dmapper not converting RJPEG images to tiff from Zenmuse H20T and Mavic 2 dual enterprise advanced thermal camera
Hi @Jonas-Dronevisual-Brazil,
Please have a look at the comment above from Kapil.
Hi @ Nikoleta_Dimopoulou . Thank you for the information. Just like Kapil.
It’s a shame DJI is encrypting the thermal data from the H20T 2 M2EA cameras, I hope this will change in the future and they release the SDK for processing.
At the moment we are waiting.
Thank you very much
What processing template did you use?
Actually this project is not mine, I found it on youtube.
However, talking to the owner, he used the common template “3D maps”, however the PIX4D is still not able to process thermal images from the M2EA, as DJI has not released the SDK for the images yet. Unfortunately.
This thermal map was generated with RGB images and changed the “Shader” to thermal. In the section “index calculator” does not appear the thermal information. You can notice at the 2:00 minute of the video, in the upper right corner, the “reflectance map” section is only using the RGB bands.
The same happens with the images from the H20T camera, as far as I know.
