Pix4dcapture compatible with Klua PPK
I am using a Phantom 4 Pro V2 with a klau ppk system and was wondering if pix4d capture is compatible with the drone and hardware and will create a ppk file if used together.
PIX4Dcapture is compatible with the Phantom 4 Pro. It works nicely together. However, I cannot comment on the klau ppk system. I would suggest checking with them to understand what their requirements are.
Thank you Mike! Working through that discussion as well. Will relay anything useful on this topic from them.
