I saw a video where this software was used with the parrot bepop drone.
is this compatible? does the camera on the bepop use geotagging? i believe so right?
You can basically use pictures taken from any drone with the mapper application. As long as the images are good quality, the software will work.
I think the bebop has geolocation, so it would make sense to tag the pictures as well.
