New release - Aug 8,2019
In this update, we’ve made some relatively small changes, with a potentially big impact on the way you work.
  • Come to the dark side. New dark/light themes matching the new Pix4D design system can be toggled on the bottom of the navigation drawer. The app option remains selected even between reloads.
  • The update prevents you from opening a project with the wrong application. Mapper/Pro projects can only be opened in Pix4Dmapper Cloud and not with Pix4Dbim (and vice-versa).
  • Some other minor improvements.
How do you change from map view to satellite in the new version?
Hi William,
There seems to have been a regression in the latest release. We’ll try to publish a fix tomorrow.
Things should work as they did before the update.
All the best,
Hugo Campos
EDIT: The issue is now fixed. Sorry for the inconvenience.
