I work on a cliff mapping project, and try to generate a MNS of that cliff. My problem is that the output does not show the overhanging parts, it smooth it!
I tried with orthoplane generation, but the output is only a .tiff and I need a pointcloud .LAS our .XYZ
Thanks!
Hi Julien,
It is possible to generate the point cloud for a specific vertical surface using the Processing Area feature to adjust the points to be densified during step 2 and extract the facade (more info).
The .tif DSM of orthoplane (orthofacade) is not georeferenced meaning the resulting file is in an arbitrary coordinate system.
This is clearly a problem for me and my clients. I need to generate a georeferenced DSM of a cliff, with a lot of overhanging areas. Will it be a future feature?
Thank you,
Julien
I have reported your need to our suggestion list that will be reviewed soon.
Thank you for your feedback Julien.
