Mavic 2 Pro
Here a brief summary from today’s launch
Camera
What are the main advantages of the cameras on both the Mavic 2 Pro and Mavic 2 Zoom?
The Mavic 2 Pro comes equipped with the all-new Hasselblad L1D-20c camera. The brand new 1-inch CMOS sensor has an active sensing area four times more effective than the original Mavic Pro. The large sensor also means better performance in low-light environments with a more extensive ISO range, and max ISO lifted from 3200 to 12800.
The Mavic 2 Zoom is all about dynamic perspectives and is powered by a 1/2.3 inch 12-megapixel sensor with up to four-times zoom, including a two-times optical zoom (24mm–48mm) for more creative aerial photography options.
Can I use the remote controller to move the Mavic 2’s gimbal 75° from left to right?
No. However, you can do this in Head Tracking mode with the DJI Goggles series.
Why can’t the Mavic 2’s gimbal shoot vertically as the Mavic Pro does?
The Mavic 2’s gimbal structure is optimized for increased stiffness, meaning that the camera is unable to rotate the full 90° needed to shoot vertically. However, you can choose the Vertical Mode in Panorama to get a stitched vertical photo.
Waypoint 2.0: Available soon.
The best.
Federico
