Mapper not connecting linear mapping mission
I am inquiring about a dataset done on linear mapping in a single flight line. My 2 ends are not connecting and offset by about 30 ft at the end of the loop. This set is from the L1 during a lidar collection so the default overlaps were at 30% for the imagery, I am trying to salvage this data collection as the LiDAR data isnt stitching due to GPS issues.
I have control points set up to help conform the map but it is still causing deviation. Any ideas to connect or bridge the two sides using mtp’s or force the two sides to connect. Thanks!
Newark BP12 Berm 11-27-24_report.pdf (881.0 KB)
