Hello! I made 4 orthosaic using pix4d and now I want to join them. I am trying to process these 4 images normally in the software, they have 2GB each and tiff format but by the time I add the images it showed error 9022. What is the best option to join this ortomosaic?
Hi Gabriel,
I guess that you got this message " Error e9022: Invalid images have been detected. Please remove them to proceed. " So I guess that you have been trying to upload the 4 orthomosaic. However you cannot do this in Pix4Dmapper. If you already have the processed orthomosaic you should merge them in a GIS software.
If you have all the images then you can either process them all together or you can process them in different projects and then merge them.
How-to-merge-projects
