How does PIX4Dmapper handle large datasets or large areas?
The question is more of how does the processing computer handle these large datasets.
If your computer is up to the task, you can process large datasets. They will take more time and need more RAM. If you run out of RAM though, the project will not process.
Pix4Dmatic is their solution for large datasets, but the processing computer’s specs still come into play.
