In PIX4Dmatic there is currently no keyboard shortcut (hotkey) to quickly toggle the visibility of the Region of Interest (ROI) on and off. Users must click the eye icon in the Content panel every time they need to see the point cloud more clearly.
Additionally, the ROI has a fixed visual appearance with no controls for opacity (transparency) or color.
These limitations reduce workflow efficiency, especially when:
Manually editing and classifying dense point clouds
Working in heavily vegetated areas
Reviewing or cleaning up terrain classification inside the ROI
Requested features (in priority order):
Hotkey to toggle ROI visibility on/off (highest priority)
Ability to select Outline Only or Outline and Fill
Ability to adjust the opacity/transparency of the ROI (fill and/or boundary)
Ability to change the color of the ROI boundary and/or fill
Version: PIX4Dmatic 2.5.2
Use case example:
When importing a larger ROI into a previously processed project and performing manual point cloud cleanup or re-running Surveying tools, users need to frequently toggle the ROI off to clearly see the point cloud, then turn it back on. A hotkey combined with opacity controls would make this process much faster and less frustrating.
Thank you!
