Help reducing background noise from trees
I am taking photos for a 3D model of a tower that is surrounded by trees.  The leaves are coming in as background noise with all the processing settings maxed for maximum density.  Any suggestions on different processing options to try?
try increasing the number of stills used to generate each point.
https://skfb.ly/Hw9M
Hello Adam, Hello Gary,
You can edit the point cloud and remove the trees around the tower.
Check this link: https://support.pix4d.com/hc/en-us/articles/204085149
and also here: https://support.pix4d.com/hc/en-us/articles/202560499
Best Regards,
