Hy everyone, this time i’m asking if you know why this “goshtly” like zone appears on the orthomosaic generated. What gives me headache is that the point cloud and the mesh shows it the way it should be, and there isn’t a camera calibration problem.
here’s some pics:
The Point Cloud with the Mesh
The Ortho
Thanks again!
Hi Sazaretto,
From the orthophoto it looks like there is a double terrain. Could you try zooming into the point cloud and check if there are two terrains? Take a look at the DSM as well. If you see a noisy DSM that would also indicate a double terrain. Would you be able to upload your quality report to get a better look?
If not already, I would switch the calibration method to Alternative and see if that fixes it.
Hope that helps!
