When applying geoid height
The existing output coordinate system is used to find the image in the center of the shooting area.
After creating a project with a geoid height of 0.000m
After checking the image, when applying geoidgo, I found an error that could not be applied after initial processing. What is the solution
Could you please give us more information about the error you mention?
Please send us some screenshots that could help us better understand the problem.
Please also send us the quality report of the project that can be found here:
(.pdf format): …\project_name\1_initial\report\project_name_report.pdf
