GCP GPS
Is there a recommended terrestrial GPS model experienced Pix4Ders use to generate GCPs? I see survey grade GPSs costing anywhere from $1000 to $5000 USD.
The higher the accuracy of the GCPs, the higher the accuracy of the Pix4D model. Most handheld GPS units are not much help - I would recommend having your GCPs surveyed with a survey-grade GPS units, either an RTK unit, or VRS at least.
Can anyone speak to entry level survey-grade GPS units? Which ones that will do the job, without having to mortgage the farm?
Thanks.
Guy,
See my post on RTK GPS:
https://community.pix4d.com/t/4703-Discussion-on-RTK-GPS-Systems
A $2,000 RTK kit is available here:
http://tersus-gnss.myshopify.com/products/rtk-bundle-915mhz
If you have a Virtual Reference Network in your area, you may get by with 1 receiver.
Thanks Ryan. The boards look pretty intimidating. Didn’t get any hits on YouTube regarding process process.
…A journey of a thousand miles starts with the first step…
