Drawing in Pix4cloud 2
Hi there. I would like to ask if you are planning to add some features about drawing, please.
For example, draw a line in 90, 45 even 60 degrees. Also if you drawing a line would be nice to start another line from the same point. I believe that all these small features would be very beneficial for future drawings.
And one more thing in my mind is that would be great if the software would be able to detect similar objects like a skylight, chimley on the roof.
Thank you, Michal.
Hi @michal.bursik ,
Thank you for your feedback!
Could you tell us more details about the angle you are interested in? Which reference should these angles refer to? Could you add some screenshots/drawings to clarify this?
This is already possible by pressing SHIFT when drawing the beginning or the end of the polyline segment :slight_smile:
For this topic, I would create a separate Community post with additional information about your goal, your use case and how this object detection functionality would help, if possible. For automatic detection, the algorithm has to be trained so it’s essential to understand exactly which shapes and objects you are interested into.
Thank you
