When creating MTP’s on the desktop software is there a somewhere where it displays which way the picture you are trying to mark is facing - as in North, South, etc?
It would certainly aid when using MTP’s.
The only way I see to do that, would be to select the image you want to mark in the left sidebar. If you select the image in the left sidebar, it will modify the borders of the image in the rayCloud view, which will enable you to see its orientation in the project:
