Hello, I have seen a few posts that seem similar to this problem, but I haven’t seen a solution. I conducted a flight with a RedEdge-P sensor at 100m AGL with 80% overlap on both sides. The raw images are crisp, but when I process them in Pix4D, then use QGIS to see the composite, a lot of the vegetation is blurry/cartoon looking.
Is there a way to fix this issue in the processing?
Thanks in advance!
