Hi PIX4Dmatic team,
I’d like to suggest a small UI improvement in the Content panel.
Current behavior
The “⋮” menu next to Ground control points has a GCP size slider, and point clouds have a size setting in the same place. Very handy. See here for GCPs:
The “⋮” menu next to Input cameras (and Calibrated cameras) only offers Input accuracies and the Ellipsoid size factor. To change the camera size I have to leave the Content panel and go to a different tab or the settings, which interrupts my workflow. Here’s the actual menu:
Requested behavior
Please add a Camera size slider with a numeric input field to the “⋮” menu of both Input cameras and Calibrated cameras, in the same style as the GCP size or point size (for pointclouds) control.
Why this helps
- Large projects (here: 2,600+ images) quickly get cluttered with camera frustums, so I often want to shrink them while checking GCPs, tie points or the ROI, and enlarge them again when inspecting camera positions.
- All display settings for a layer would sit in one place, consistent with GCPs and point clouds options there.
- Fewer clicks for something that gets adjusted many times per project.
Thanks for considering it!
Manuel Allinger
Octacon Geotechnik GmbH
