I would like to select a large number of existing volumes in order to change their filters and resolution. Later, everything should be recalculated together.
Example: If the point cloud is filtered after the volumes have been created, the changes to the volumes currently have to be made individually and recalculated.
Here’s what I’d like to do: Changing the filter and resolution should clear the volume calculations so that the changes take effect later and all the volumes can be calculated together at a later time.
I’d like to select a few volumes, set their properties, save them, then select a second group of volumes, change their properties again, save those, and have everything calculated together later!
The simplest solution would be for changes to properties or filters to simply clear the calculation of the corresponding volumes and mark the volumes as “to be recalculated.”
