I’m facing a problem when processing images taken with a Panthom 4 Multispectral with DRTK-2 station above a peatland (camera at 90°, ground pixel 1 cm, flight speed 2.5 m/s, automatic camera setting, capture at equal time interval 2 sec).
Raw Images captured are well exposed, clear and shap in all 5 bands. After I processed images the final reflectance tiles are blurry in most bands (exept blue).
Do you experienced this problem before ? What did I wrong ?
Best !
Hi @romain.walcker,
Could you please send us the following?
▸ The quality report (.pdf format): …\project_name\1_initial\report\project_name_report.pdf
▸ The project file (.p4d): …\project_name.p4d
the log file is too big to be send
Could you process with internal paramameter optimization “All”.
Otherwise please submit us a ticket as you have a valid Support license. SupportTicketForm
Hi Jose,
I processed with internal parameter optimization set to “all”.
Here is the report of step 1.
Would you like me to submit a ticket ?
BernadouzeSP2_report.pdf (1.8 MB)
Thanks for the information sent, yes please submit a ticket for us.
Best, José
Hello, I am also getting this problem. Could you please explain how to fix it? Thank you
Hi Carlos,
Can you attach your quality report to this posting?
