Currently, PIX4Dcloud does not provide a way to download datasets or outputs from multiple projects at once.
I would like to request a batch download feature at the Project Group level. Users should be able to select one or more output types (e.g. point clouds, orthomosaics, DSMs, reports, or original datasets) and download them from all projects within a Project Group in a single operation.
Use case:
In construction, surveying, and infrastructure projects, a Project Group can contain dozens or even hundreds of datasets. These datasets are often collected through both drone surveys and mobile mapping workflows using PIX4Dcatch in combination with viDoc or Emlid GNSS receivers.
For archiving, quality control, progress documentation, or further processing, for example in PIX4Dmatic, data currently has to be downloaded individually from each project. This is particularly relevant for Field-to-BIM projects, as-built documentation, and utility mapping workflows in civil engineering, where data from many projects often needs to be processed together.
Manually downloading outputs from each project is time-consuming and increases the risk of datasets or output files being overlooked or forgotten.
Benefits:
• Significantly reduced manual effort
• Faster archiving and data management
• Improved efficiency for large Project Groups
• Reduced risk of incomplete data collections
• Optimized workflows for drone and mobile mapping data
A batch download feature would be a valuable enhancement for users managing large numbers of projects and datasets in PIX4Dcloud.
Thank you for considering this feature request.
