Hi, I am using DJI Matrice 100 to acquire data over seven different locations. The problems are:
After processing the data, the elevation error is high which up to more than 20 meters.
For certain area, the elevation value is negative.
Orthomosaic result showed that one object appear as multiple especially for high object as an example transmission tower.
4. The orthomosaic photo is inaccurate especially for high object
Therefore, it would be much appreciated if Pix4d or anyone could help in solving these matters. Thanks
