When modeling house accurately, it’s tough to spend time for setting manual tie point. Is there better ways to do it? Set airphoto signal anywhere (I can set)? Flight plan is all the matter? Thank you.
HI Takeyuki,
It is indeed very important to adapt the flight planning to the task that you want to undertake.
If you want to model a house, you can find recommendations on how to fly here.
By following this procedure, most probably you will not have to measure Manual Tie Points to get a good result as the software will be able to find the necessary keypoints and matches.
As you suggest, including GCPs located on the facades of the building can also help and it is the recommendation to get the most accurate results.
